Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Vragen Bekijk alle
MacBook not turning on after speaker replacemen ‘URGENT HELP’
Hello, hoping everyone is in great health.
I had a bad speaker in my Macbook 2015 15’inch Retina. So i planned to change it myself. I took out the back cover removed the fan but realized i forgot to take the battery cable out so the laptop turned on then i shut it off through the power button and took the battery cable out took the fan out replaced the speaker then i had somewhere to go so i left the mac open for an hour or two then came back put it all back together but not it does not turn on. No fan, no keyboard lights nothing. When i plug in charger does work it goes orange / green . But the laptop does not turn on
I reset the SMC thing. No hope
Pressed the power button for 10/30/60 seconds nothing
Removed & reconnected the battery terminal nothing
Can someone please guess what could go wrong?. I’m sure I didn’t damage any wires since this was not the first time i was repairing something.
I need to sell it to a customer tomorrow now i’m stuck with a broken mac
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Best to call your friend as your system will need some repairs to the logic board before he can buy it. Forgetting to disconnect the battery did you in ;-{
Was dit antwoord nuttig?
2 opmerkingen:
But i just removed the fan that also for a second the laptop turned on fine then i shut it down then disconnected the battery and continued my work. Removing just a fan with battery connected is really an issue?
door
The MOSFET driver for the fan is sensitive! I've seen this before. It shorts out and kills the power rail.
door
Voeg je antwoord toe
Aleem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 92
