Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
352 Vragen Bekijk alle
After installing the SSD?
Hi after I’ve installed my SSD in the optical bay how do I go about making the optical (SSD) the targeted drive with HDD storing what can't fit on SSD (250GB)
The main drive has two partitions High Sierra and Catalina which is all backed up on my time machine.
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
1 Antwoord
Het nuttigste antwoord
You need to install macOS onto the drive. Download the OS installer from here: How to upgrade to macOS Sierra Jump down to Set 4 locate the blue URL link Download macOS Sierra to get the OS installer. You’ll need to setup a bootable OS installer on a thumb drive How to create a bootable macOS Sierra installer drive. During the OS install it will alter the boot drive to the SSD you just installed the OS onto.
I really don’t recommend forcing Catalina onto your system as its not the best OS for it. The best is sticking with Sierra 10.12.x as well as using HFS+.
APFS is great if you have a PCIe/NVMe drive! Older SATA drives (HDD or SSD) just don’t run well with APFS. To add to this Catalina doesn’t support older 32bit apps and frankly its still buggy!
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Dawoud Ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 11
