Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
355 Vragen Bekijk alle
Will installing PCIe SSD slow down fan if HDD damaged?
Hi there :)
I got iMac 5K 2014 27” which had HDD but removed as died.
Now because no HDD fan is full on as thermal sensor in HDD is missing - would it fix it installing PCIe SSD (original Apple or NVMe with adapter)?
All I know all iMacs originally shipped with PCIe SSD only (without HDD) fans were working fans as normal.
Do they have “special” different firmware or just if iMac detected removed HDD but installed PCIe SSD automatically “cure” itself
Thank You for help
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
1 Antwoord
A blade SSD model would have a jumper on the logic board to disable the HDD sensor.
Your options are just put in a replacement SATA 3.5” HDD or a 2.5” SSD with the OWC in-line sensor and call it a day.
Or, put in the correct Apple or OWC blade SSD into the PCIe/NVMe blade drive slot to gain the most performance.
I personally don’t like using the M.2 SSD’s with their funky adapters in iMac’s given how difficult they are to get to it’s just not wise! To put in bluntly, I have a very full drawer of dead M.2 SSD’s and adapters I’ve pulled out of Mac systems! The quality of the drive and the adapters as well as the way Apple setup the custom interface these M.2 SSD’s just can’t emulate.
Was dit antwoord nuttig?
Voeg je antwoord toe
Bart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 16
