Ga door naar hoofdinhoud
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4941 Vragen Bekijk alle
Half the screen of my iPhone is completely black with colored lines
Hi, I replaced the screen on my iPhone 6 and now half the screen is black and there are vertical colored lines and the other half is really glitchy and like is flickering really fast. Touch screen and everything else seem to work, just the display. I would appreciate any advice . Thank you!
Is dit een goede vraag?
Commentaar:
Ok thank you! I will try it out and see if it works
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like a bad connection. Take a magnifying glass and make sure the connector is not damaged. Then clean it with a qtip and alcohol and a soft brush. Make sure you disconnect the battery before unhooking the screen connectors. There is a possibility that you have a defective screen.
Was dit antwoord nuttig?
Score 1
Commentaar:
Allen is right. This sounds like a connection problem.
door
Voeg je antwoord toe
Anshul Verma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 36
