Ga door naar hoofdinhoud
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
142 Vragen Bekijk alle
Why will my horn not stop sounding
How doing get to the horn switch in the airbag module?
Is dit een goede vraag?
1 Opmerking
Can you explain this a little better please. I doesn't make sense.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Sounds like your alarm system is setting the horn off. Use your valet key and lock the driver side door then unlock it.
Was dit antwoord nuttig?
Score 1
It sounds like the horn button on the steering wheel has the foam padding compressed and when the temperature changes it can cause the horn to go off. You will have to get a new airbag assembly or take out the horn relay or unhook the horn. This is a common problem especially if it gets cold in the area the car is.
Voeg je antwoord toe
Eric Lynn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 91
