Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2686 Vragen Bekijk alle
Why wont my phone turn on when I press any of the buttons?
my iphone 6s wont turn on when i press the home or lock button. i kept it on charge all night for more than 7 hours. but it still wont turn on when i press any of the buttons, however it does randomly flash my lock screen for point 2 of a second then turn off. i dont know what to do. anyone hvae any ideas?
Is dit een goede vraag?
Score 1
2 opmerkingen:
What happens when you plug it in to a charger?
door
Do you feel vibrations when you use the mute switch?
door
Voeg een opmerking toe
2 Antwoorden
Hi! Due to the age of this phone, I would expect the battery to start degrading, you most likely need a new battery or a new lightning connector.
Was dit antwoord nuttig?
Have you tried a different charger? If that won't work, you may have to replace the charging port. Before you try replacing the port,try using the compressed air can for electronics and blow out the dust in the port with canned air. That worked for my 6S plus.
Voeg je antwoord toe
Taylah05 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 57
