Ga door naar hoofdinhoud
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Vragen Bekijk alle
Replacement screen not sticking to device
I have replaced the screen on an iPad as the original was cracked. The new screen does not stay fully attached to the device, does the adhesive need to be heated for it to attach?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Which areas are pushing up? If its the bottom left you’ll need to use B7000 liquid glue to hold that corner down and use scotch tape to keep pressure on that spot until the glue sets.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
It’s most sides apart from the top, I’ve reattached for now but will need to glue if doesn’t hold. I know some adhesive needs heating to activate so checking I hadn’t missed anything
door
Voeg je antwoord toe
Michael Jones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 64
