Ga door naar hoofdinhoud
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
562 Vragen Bekijk alle
My MacBook died after I plug my power cord
My macbook suddenly died as soon as i plug my power cord with 30% battery. I tried to reset but did not work at all. Im not sure if it makes sense because i am in Philippines and power voltage is different . Might be short circuited? Please help. Im losing it and its covid lockdown. :(
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hope you figured it out but if not - your Mac most probably alive.
No the difference in the voltage should not do any harm unless it delivered in spikes of enormous amplitude which should be rare even in Philippines
Could you please precise with what key combo have you tried to restart?
Have you tried Control+Option+Shift+Power button?
If not - try it.
Same key combo as for SMC reset but one quick press.
If it is up and running - great. If not - try to do SMC and PRAM reset and see what’s happening. Normally it should fix your A1708.
If not - I would first check the power supply module whether it is working with something else.
If it is working and your Macbook Pro still show no signs of life then the deeper investigation will be necessary.
Let’s hope it will not be that serious.
Please post your findings and we will proceed from those.
Was dit antwoord nuttig?
Voeg je antwoord toe
Victoria zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 31
