Key won't go back in properly (butterfly keyboard)
Hi there, my T key on my Macbook Pro has fallen off. The key looks 100% in tact: the two top clips don’t seem damaged, and the two bottom hooks don’t seem damaged.
However when I try and put it back into place, I can’t get it to “click” in. Has the butterfly mechanism broken? It’d be great if I can try fix this myself as it’s currently lockdown in the UK so can’t get to an Apple store - I also fear it’s an expensive fix otherwise.
Is dit een goede vraag?
6 opmerkingen
Don't forget Apple has a free repair program for systems with butterfly keyboards.
door DanJ Deel
I've used it so many times they won't do it again for me now!
door Samuel Franklin Deel
@Samuel Franklin - Remind them! Its a free repair under this program! Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro Make sure you are going to either an Apple Store or authorized Apple reseller as they will fix this and if this is the third time the will likely exchange the full uppercase! Which gets you a fresh battery as well.
Don't lose out of a free repair!
door DanJ Deel
A few notes about the program from a local Apple repair shop that I called. First, they program will end at some point, and like your warranty, the end date is based on your purchase date. When mine was run by the shop, it noted August of this year is the end for my MBP. Another thing is they WILL NOT repair it if you have replaced the battery (I replaced my battery a few months back). In fact, if they feel like you've been in there much at all, there's a good chance it will be returned without being fixed.
door Charles Deel
I have a similar case with my H key. this time, its stuck into the keyboard. anyone have a solution?
door Bill Wang Deel
1 commentaar meer tonen
