Ga door naar hoofdinhoud
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
Lid making grinding noise when I close it
Hello,
I have some sort of an issue with my MacBook pro 2019. Whenever I open the lid above 90 degrees, and when I close it, it makes kind of a grind noise as something is touching inside between the lid and the antenna.
https://youtu.be/Ra6F_XZVqMg
This is the noise that is making.
What is your opinion about this stuff? Did you seen or heard anything like this?
Thank you
Is dit een goede vraag?
2 opmerkingen:
Did you bang the system or have something sit on it?
Something is bent or out of alignment!
door
No, it,s just out of the box brand new, no hits . Everything seems ok with it execept with this thing. I will try to remove the back cover to see whats up but i can't find a pentalobe screw
door
Voeg een opmerking toe
2 Antwoorden
No! Don’t mess with it! Time to visit an Apple Store for them to fix it.
Was dit antwoord nuttig?
1 Opmerking:
To late haha . i ve opened it it s the plastic cover of the display rubbin a bit on the antena. Dunno why… but i believe it s not so much big of a deal… i live in Romania… here is a bit hard to find a good apple service unfortunatley :(
door
As it is an Apple product, I would advise you to take it carefully from here.
Shake the laptop mildly and notice if something is loose inside it.
If there is no such thing then don’t open it. Take it to the Apple service center.
I hope this helps!
2 opmerkingen:
Yes when I shake it with the lid closed it s a slight noise coming from the inside.with the lid opened no noise...
door
Any ideas? The interior looks fine
door
Voeg je antwoord toe
cvld88 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 548
