Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 Vragen Bekijk alle
Vraag afgerond
How to remove broken glass?
Hello,
The glass of my touch 4g broke, and i was wondering how i am going to remove tiny bits of glass of the screen? Becouse i think the tiny glass bits will stick to the panel.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
the tiny bits of glass tend to stick to the adhesive holding the glass panel in place. I'd wear safety goggles/glasses etc as sometimes despite your best efforts something flicks up. When you scrape the adhesive off the glass will come with it..it's very sticky.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks, i'll get the glass tomorrow, wish me luck!
door
The front panel is glues onto the screen so you need to get a new one And its expensive
Use a heatgun to remove the glass, the tricky part is reattching the new screen after you get the old one off. The connection faces the back of the device instead of the front so you have to remove some screws and do alittle bending to get it in there. I had these guys fix a few for me in the past, they did a pretty good job. www.HookUpCellular.com
1 Opmerking:
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,077
