Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en Probleemoplossing voor de EasyNote TJ65-CU-030GE, een 15,6" budgetlaptop van Packard Bell.
Curser won’t move when laptop switched on it all lights up but cannot.
Open anything up to find the answer. Have changed the battery I; the mouse but should have still been able to move curser with finger. The switch can be pressed for to switch laptop off but that is all . P.ease advise me some one
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Hi,
Do you mean that none of the buttons? on the left side multi media board below the Power button are working and that you cannot enable or disable the touchpad or anything else using those buttons?.
Here’s an image taken from the service manual for the laptop that shows the buttons, including the touchpad enable/disable button, that I mean.
Afbeelding
(click on image to enlarge for better viewing)
You may have to check if the left multi media board cable is securely connected at both ends, media board and motherboard in the laptop.
Go to p.80 in the manual to check where to find it.
If the media board is faulty, I cannot find a replacement board when searching online using the part number, (part #55.BCR01.003). All the suppliers say NLA (No Longer Available). You may have better luck
In the meantime to be able to use the laptop, connect a USB mouse to navigate through the laptop.
What OS is installed in the laptop, Win XP, Win 7, Win 10 etc?
Was dit antwoord nuttig?
Voeg je antwoord toe
annegoldie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 307
