Ga door naar hoofdinhoud
iPhone won’t boot and shows pixelated Apple logo
Hello, I am having a bit of a trouble with my iPhone 7. A few weeks ago, the phone was working perfectly until it began to shut down randomly. A soft reset would resolve the issue but the phone began to shut off randomly even more. I have tried to restore it many times using iTunes or on the iPhone but that did not fix anything. I have changed the battery which fixed the issue for a day and then the same problem. Now my iPhone won’t even boot after a soft reset. It sometimes shows the Apple logo with a pixelated screen and then go back to a black screen. It does show perfectly however the “plug in you iPhone” sign when you don’t have any charge left. Does anyone know what might be causing this issue ? It is pretty annoying. Thanks for your help. :)
Is dit een goede vraag?
Score 1
1 Opmerking
Looks like a logic board issue you should take it to a microsolderer
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Not really, I just replaced the whole motherboard which fixed it obviously
Was dit antwoord nuttig?
Het nuttigste antwoord
That’s a board issue which is most cases on GPU line. Are you a technician? if you’re look on GPU line and do measurement.
Score 1
4 opmerkingen:
No I am not a technician but I am used to fix phones. What should I do ? Do you think it can be fixed ? Thanks for your help !
door
have a look on our GPU line!
door
@kiwi456 Have you found any solutions? @hpi can you help me about the "GPU line measurement"?
door
Oh, that's bad. Do you know where can I find a motherboard?
door
Voeg je antwoord toe
Charles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 306
