Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
iPhone not working after screen replacement
My screen was cracked so I purchased a digitizer with midsection from a reputable online store.
i followed the installation guides on youtube and 'succesfully' replaced my screen.
only problem is my phone now wont turn on:( It has a dull grey backlight but nothing on the screen.
My phone responds to txts and calls etcbut no screen
Help !!! :( :(
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I have similar experience, just two days ago I replaced my 3gs LCD. Everything seems right, I checked and rechecked connectors 1, 2, and 3 to make sure they're all placed correctly. When I turned it on... the display on but showed "white backlight". When I charge my phone, I hear click sound, so I am sure the problem in on LCD.
Here are the steps I did to solve my problem: 1. connect 3gs to itunes (on my laptop), all apps were displayed virtually on my itune; 2. reset the system software to factory setting (thankfully itune ask backup all data first); 3. folow itunes instruction until the system restart on you computer, if you can see any instruction on your iphone display, then everything will be fine; 4. restore all data and iphone system to newest version.
This is what I think the possible problem, either when you replace your digitizer, your iphone wasn't turn off or the iphone system software does not recognize new part replacement (digitizer or LCD) so it requires system resetting with iTunes.
Hope this info could be helpful.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
You, my friend, are a genius and have sorted my phone!
Thanks
door
Does the old screen work with iphone? If not, check the new displays connector if it is dirty or loose. It also may be the logic board connector. Logic board's connectors can be easy to break if you are not careful.
1 Opmerking:
"dull grey" not black
door
Voeg je antwoord toe
amielambkin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,758
