Ga door naar hoofdinhoud
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Vragen Bekijk alle
Need for more Speed. An upgrade Question.
I want to squeeze out some more life of my mac mini 1.83Ghz.
I am running snow leopard with 4GB Ram and 500gb HD. (Can't remember the HD but it is a faster one)
I am afraid Lion will slow it down even more. I want to make it faster. What to do? Ssd? Cpu change?
Or does it make more sense to buy latest 2011 model?
Thanks in advance for you input.
Update
I broke down and upgraded.
I got a ssd drive. It seemed easier then replacing the CPU.
I might still consider CPU upgrade if I can find one cheap enough.
I got a Corsair Force 3 @ Newegg. It had good specs. I got the 120gb version but regret that I didn't get the bigger one.
For a comparison I did a xbench before and after.
xbench with 7200rpm WDC HD was (Disk test)64.43.
xbench with ssd was (Disk test)243.85.
sequential w/HD 101.94
sequential w/ssd 148.85
random w/HD 47.10
random w/ssd 673.98
Night and Day the difference.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I would opt for a complete upgrade to a newer Mini. You have a core solo machine and it's only going to bottleneck the systems performance even with an SSD and max RAM. Don't get me wrong, a good SSD will greatly improve the performance for your machine, but I would opt for a newer Mini, then place an SSD in place of the HD, and you'll be a happy camper for a few years to come. That's just my opinion though. ;)
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
My 1.83Ghz machine is already a C2D and MAX out at 4Gb of Ram. I am considering a new machine but if I spent the $$ on a newer machine I would not be able to do upgrades, like ssd.
I just double checked and my machine has a
Intel® Core™2 Duo Processor T5600 (2M Cache, 1.83 GHz, 667 MHz FSB)
door
Oh ok. Your model identifier says it is a core solo on the top of the page. Core 2 duo is pretty fast. Place a good SSD in there and your 4 GB of RAM are plenty unless your doing photo or video editing. I wouldn't upgrade to Lion if you can only go up to 4GB of RAM.
door
Het nuttigste antwoord
I installed a 2.16 GHz Intel Core 2 Duo CPU into a 1.83 GHz Core Duo 17" xbench on the original was 117.88, CPU 78.21 New configuration is 154.06, 154.06 CPU. This compares to the 2.66 GHz '08 & '09 machines.
Score 4
3 opmerkingen:
I only worry about heat with changing from a C2D 1.83Ghz to the blazing fast 2.16Ghz C2D. Did you notice any problems with heat?
door
No heat problems at all. I used a T7400, just remember to replace the thermal paste.
door
You should be able to get the processor on eBay for $100
door
If I change the CPU and add a ssd then it will max out this machine.
The total cost for both is around $500-$600.
It is so close to a new machine cost that I am starting to lean towards buying a new one.
1 Opmerking:
I agree. macs have a high resale value. You can always sell your old machine and use the money for a newer machine. I was able to sell a Early 2009 Macbook for $500 with no problem. Save the upgrade money and sell your machine and just get a new one. That's my opinion.
door
I bought a 1.83 GHz C2D A1176 Mac Mini (2007) for $150 on eBay. I bought 4GB RAM for $45, it already had Lion installed. I bought a 500GB 5400RPM HD for $50. I bought an OWC SSD for $70 and a caddy $50
Total Package: $365 but the SSD and 500GB hard drive will step this machine up for a while. The smaller of the two new Mac Minis is $600.
I have another mac mini A1176 Core Duo. I upgraded the processor with a T7600 for $30 (Amazon) and formatted the 80GB drive and installed Snow Leopard which I have already. I did buy a new optical Superdrive ($50) because I want to play DVDs on the beast. I left the original 2GB memory in it because I don't want to risk the firmware upgrade in case I end up with a brick. So $80 and I have a fairly decent upgrade.
Voeg je antwoord toe
alfredo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,040
