Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
373 Vragen Bekijk alle
What work do I need done?
On my screen, at the bottom right corner there’s a black splotch/blob. It started small and slowly is growing, and now my phone has the ghost touch. Whenever I try to type it’ll start pressing all over the screen. What will fix it? And how much will it cost? Are stores even open now for it to get repaired, due to the coronavirus?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
broken oled you will need to replace the display on an xs max is can get pricey i would just call around to the local repair shops they should still be open (at least around my area they are )
Was dit antwoord nuttig?
Hi Denise,
Sounds like your display is faulty, depending on when you purchased the device you may still be under warranty. First step would be to visit apple.com/support and check warranty status. If there’s no other damage to it it may well be covered and they can walk you through the process.
If not you can get it fixed through Apple if you’d like at a cost. It varies between countries a little but visiting https://support.apple.com/iphone/repair/... should give you some idea.
Given that we’re on iFixit, if you’re confident with electronics repair / can follow the guides and want to give it a go. check out https://www.ifixit.com/Store/iPhone/iPho... It sounds like a screen replacement would sort the issue.
Hope this helps!!
Voeg je antwoord toe
Denise Nguimdoh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 56
