Ga door naar hoofdinhoud
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
Touch Bar not working ,tried 4 different types of resets
Touch Bar on 2019 MacBook Pro stopped working and have tried 4 different types of resets
Is dit een goede vraag?
1 Opmerking
Can you list out what you've tried so we don't repeat.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Your system is likely still under warranty, if you took out the AppleCare+ extended warranty you also have it, I would recommend you call Apple to at least check.
Its a bit of work to get the old Touch Bar out to replace and right now the part is not available. Apple basically replaces the full uppercase assembly.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
1-800-myapple
door
Voeg je antwoord toe
ron e zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 136
