Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
831 Vragen Bekijk alle
Replacement Screen Won't Turn On . Bricked A Replacement Screen?
Hey guys!
So I’ll cut to the chase because I’m pretty stressed right now. I was doing a screen replacement on my SE and as I was reassembling I connected the 3 top connectors and the battery and did a screen test. The screen lit up and asked for my password but I noticed that the screen did not respond to my touch. Noticing that one the 3 top connectors had come undone (the bottom-most one), I tried to turn the phone off. However, since the screen did not respond to my touch, I couldn’t turn it off the normal way and foolishly just went at the problem by disconnecting the battery connector and then the 3 top connectors until the screen went dead. Second time round, the screen won’t turn on at all.
Plugging my phone into my PC, I find that the phone vibrates (3 times) and that iTunes asks if I’d like to install an update.
Please help. I’m not sure if I just bricked the replacement screen and need to buy a new one or that my phone is now destined for the recycling centre.
Thanks in advanced, stay safe and stay healthy
Is dit een goede vraag?
Voeg een opmerking toe
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Koop iPhone-reparatiekits
SLA DE UPGRADE OVER
1 Antwoord
you may have fried it.
typically ill let a device completely die before even working on it.
that way if something like this happens i dont have to wait long for it to die and turn off that way.
my only advice would be to take it apart again and look to make sure all the connectors are still good. if so then you may have fried it :( the only other way to test it unfortunately is to buy ANOTHER replacement and see….
Was dit antwoord nuttig?
Voeg je antwoord toe
TreeAndPlants zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 22
