Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Vragen Bekijk alle
SSD Upgrade from 512GB to 1TB on MacBook Pro 15" Mid 2015 Retina Displ
i read some forums on this subject but im not sure i got my answer, i’ve reached my macs limit, had to delete alot of stuff this last months, and i was looking to replace my battery since it goes from 40% to 0 and shutting off in one second sometimes, so i thought to replace my SSD from the factory ssd that i have of 512GB to a 1TB SSD, but i want to know if theres any compatibility issues, i read on another forum that only apple and OWC make ssd replacements, but is there any problem like will my mac only read 512GB when i have 1 TB or will it use the whole 1000GB
Is dit een goede vraag?
Score 1
1 Opmerking
I did the upgrade on my Early 2015 MACBOOK pro using the OWC 1TB and it was easy and Ive had zero problems.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
There shouldn’t be any problem with using the whole disk space after the upgrade.
I would stick with one of the recommended suppliers as I’ve had problems getting hold of compatible Mac SSDs in the past.
All the best,
Alan
Was dit antwoord nuttig?
7 opmerkingen:
is there by any chance any way to clone my current ssd to the new 1tb ssd, cause i still want to keep all files and applications
door
@dullatpg Yes, do a complete Time Machine backup to a spare external hard disk, put the new SSD in the Mac and when you reboot you should have the option of restoring your system from the Time Machine backup
door
ok, the ssd will be empty so will i have to install mac os from a usb bootdrive?
door
@dullatpg No, when you boot up with a blank SSD the act of restoring from a Time Machine backup will also install the operating system.
door
ok, thank you for the help, appreciate it
door
2 commentaren meer tonen
Voeg je antwoord toe
Dulla TPG zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 758
