Ga door naar hoofdinhoud
De Xbox draadloze controller 7MN-0001, vervaardigd door Microsoft Corporation, is de meest gebruikte controller voor Xbox-spelcomputers en kan ook in combinatie met pc's worden gebruikt.
127 Vragen Bekijk alle
Does this have bluetooth?
I tried to link it to my phone to play a game and it won't link?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No, the 1537 uses 2.4ghz to connect to the console and/or an Xbox wireless adaptor for Windows. I have an Android phone and I've successfully used an OTG cable (Type C or whatever port your phone uses, to urb type A) plugged into a micro USB, plugged into my controller. If you're looking around for the Bluetooth model, you're looking for the 1708 or the new Xbox one elite controller. They're the only 2 that have onboard Bluetooth capabilities.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Thank u so much, yeah, I'll need to go get a 1708 IG, I asked the guy at gamestop specifically for the Xbox controller with built in bluetooth, and he gave me the 1537, slightly !#^&@@ but it is wat it is, I'll just need to make sure to get a newer one saturday wen I go
door
Oof, sounds about right lol
door
I had this same problem. Thank you for your help
Score 1
Voeg je antwoord toe
Erik eliott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 79
Afgelopen 30 dagen: 419
Altijd: 18,993
