Ga door naar hoofdinhoud
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
70 Vragen Bekijk alle
Used compressed air to clean speaker/mic grills and the back inflated.
Title says it all pretty much.
I was using compressed air to clean the mic grill of my Pixel 4 XL and the rear glass started lifting up/inflating slightly from the frame. I think air was coming out of it. Did this just damage any of the water resistant seals on the phone? The rear glass went back flush with the phone and it doesnt seem as though anything is damaged. I'm just worried that I may have damaged the water resistance seal in the back of the phone.
Is dit een goede vraag?
1 Opmerking
The phone (or any water proof or water resistant device) is not designed to support a higher air pressure from the insides than the ambient pressure.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It is possible that you damaged the waterproof seal, however, if its any reassurance,the waterproof seal was probably compromised anyway. This happens over time with normal use.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Tyler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 133
