Ga door naar hoofdinhoud
Model A1224 / EMC 2316 / 2.26 GHz Core 2 Duo processor / Education only model. Released on March 4, 2010.
15 Vragen Bekijk alle
cant run high sierra
I tried running high sierra but it wouldn’t install so i assume that os is to advanced for it, which was the original os for this imac?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Here’s how to do it:
Requirements:
• Early-2008 or newer Mac Pro, iMac, or MacBook Pro:
• MacPro3,1
• MacPro4,1
• iMac8,1
• iMac9,1
• iMac10,x
• iMac11,x (systems with AMD Radeon HD 5xxx and 6xxx series GPUs will be almost unusable when running Mojave. More details are located in the Known Issues section below.)
• iMac12,x (systems with AMD Radeon HD 5xxx and 6xxx series GPUs will be almost unusable when running Mojave. More details are located in the Known Issues section below.)
• MacBookPro4,1
• MacBookPro5,x
• MacBookPro6,x
• MacBookPro7,1
• MacBookPro8,x
Hoe installeer je macOS Mojave op Mac's die dit niet ondersteunen?
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
@obsoyeet - Your reaching! This series (A1224 / EMC 2316) RAM (8 GB) & SATA II (3.0 Gb/s) limitations really won't run these newer OS/s very well and you loose quite a lot of the features they offer which is why people want them.
door
OS-X El Capitan 10.11.x is the highest it can go, sorry ;-{
Your systems specs: 20” iMac 2.26 GHz Core 2 Duo (Mid-2009)
Score 2
Voeg je antwoord toe
MATTHEW AREIZAGA zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 247
