Water leak in straight stream out of the timing cover
My van has a straight stream of coolant squirting out between the timng cover and motor how do I fix this thanks in advance
Is dit een goede vraag?
Replace the timing cover gasket.
UPDATE 3/5/20
Here’s how to do it:
Was dit antwoord nuttig?
I kinda knew that but how to do it I don't
Hi,
Check that the water pump is not leaking coolant.
Here’s a link to the service repair manual for your series vehicle.
Scroll down and click on the Cooling System link , pass the reCAPTCHA test and when the pdf file opens go to p.7-19 to find the procedure to inspect / replace the water pump for a 3.8L engine.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 126
2 opmerkingen
Hi,
What is the model year and engine size?
door jayeff
Model is a 2000 it has a 3.8 engine thanks
door Daniel Billings
