Ga door naar hoofdinhoud
Reparatiehandleidingen, informatie over demontage en probleemoplossing voor de 4e generatie Apple iPad met CDMA 4G LTE mobiel netwerk (Verizon), beschikbaar met 16, 32, 64 of 128 GB opslagruimte. Uitgebracht in november 2012. Te identificeren aan het modelnummer A1460.
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
Is dit een goede vraag?
1 Opmerking
I don’t know what I did different, but I got the display to work.
Thank you for the replies
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
Was dit antwoord nuttig?
Score 1
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
Voeg je antwoord toe
sunruh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 391
