The machine is making weird loud noises and it won’t drain until after
My machine is making a loud noise and won’t drain the load. If I do the cycle again and agin it will finally drain
Is dit een goede vraag?
Score
0
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 18
Hi @bballermama ,
What is the full model number of the washer?
Is it a humming sound like the drain pump is trying to operate?
Can you make it drain by manually selecting the spin position on the cycle timer switch or one notch past the start of the spin cycle?
Depending on the model it seems like a faulty cycle timer switch.
door jayeff
Thank you I will look at that It does drain but leaves the clothes soaking wet I put it on the spin and drain cycle after that but it did not make the clothes any less soaked
door gmarchant9
Hi @bballermama ,
Model number please?
So it is not spinning then, just draining is this correct?
door jayeff
