Ga door naar hoofdinhoud
Reparatiehandleidingen voor spullen die gebruikt worden in combinatie met telefoons zoals headsets, laders en koffers.
126 Vragen Bekijk alle
Element Enigma Phone Case Repair
I recently bought the Element Enigma Phone case for iPhone XR, the slightest thing that scrapes against it scratches the aluminum bezel. Is there any way to buff this out and fix the paint?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@doctorsleepy if you are that attached to this expensive case I’d suggest an automotive body shop. You’ll be surprised what they can do. Should not cost you any more than the case itself but you can get it at least painted with paint that will not scratch easily off. Or you can get it electroplated. All of this will of course depend on how much you want to spend on it. If you want to minimize the expanse get a buffing wheel and buffing paste from your hardware store and carefully buff those scratches out yourself. After that you could use some rattlecan paint made for aluminium surfaces to cover it again.
Was dit antwoord nuttig?
Voeg je antwoord toe
Cary Hess zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 41
