Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
1545 Vragen Bekijk alle
NFC Not Working After Rear Replacement
Hi All,
I have an ongoing issue with all iPhone models where NFC won’t work after replacing the rear case. In some cases, swapping out the NFC antenna works however not always.
When changing the antenna doesn’t work, is there something else I can do, a component on the case that can be added or replaced? Is it an insulation or grounding flaw with aftermarket cases? If so, can it be remedied?
On the devices in question, NFC has been tested and proven to be working before the swap and again when the board is transferred back to the original case.
I’m grateful for any help or suggestions, thanks in advance!
Is dit een goede vraag?
Commentaar:
I decided to tear apart a case to see if there is anything in the fabric of how it is constructed…
[image|2007626]
[image|2007622]
The screw that grounds flat to the back of the rear seems really straight forward and doesn’t connect to the plastic antenna band. It also seems that the end that connects to the top edge also has no special make-up.
Still interested in hearing other people’s theories…
door
Voeg een opmerking toe
LCD iPhone-scherm fixkits
De goedkope optie, ondersteund door onze levenslange garantie.
Koop kits
Bespaar op reparatiekosten, niet op kwaliteit.
Koop kits
3 Antwoorden
after have you tried replacing the NFC IC chip?
LINK
Was dit antwoord nuttig?
Commentaar:
No because if I put the board back in original case the NFC works, the issue is with the new cases rather than the board. Thank you :)
door
did you ( or are you able to) check the new case with a another iphone 7 if it is working
door
Yeah, I tried the case with different boards so its definitely isolated to the case.
door
I think it is a grounding flaw with aftermarket cases , not only problem with NFC but sometime also other issues.
Commentaar:
Yeah, it seems that way to me. I did wonder if a slither of grounding tape could help the issue but thought it might cause more problems than it solves.
door
Voeg je antwoord toe
All Seeing Aye zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 48
