Ga door naar hoofdinhoud
The Mercedes-Benz W126 is a series of S-Class automobiles manufactured by Mercedes-Benz between 1979 and 1992. Premiering in September 1979 as the successor to the W116 line, the W126 was the second generation to officially bear that prestigious designation, an abbreviation for the German Sonderklasse or "special class." The W126 was initially offered with straight-six, V8, and a turbocharged diesel engine for the sedan. A C126 2-door coupé versions was introduced in September 1981.
11 Vragen Bekijk alle
How to install a push button start on my 1983 Mercedes Benz 300 SD?
How to install a push button start on my 1983 Mercedes Benz 300 SD? Will this make it where I can start my car still if I lost the key or have problem with the starter? If so…this would be wise to install! Thanks
Is dit een goede vraag?
1 Opmerking
What is the real problem with the car? Is the engine hard to start, or is the key stuck and won’t turn in the ignition? Did you loose the key?
It would be bad to bypass the ignition with a push button, someone could easily steal your car.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Maria Stockstill “Will this make it where I can start my car still if I lost the key” you would have to rewire the ignition lock so that you get the accessory power going which you will still need even if you go for a push button start. So you will still need to have some additional switches installed. “have problem with the starter? “, no. A push button starter still only close the circuit to the starter. It will not resolve any starter issues. Take a look at the wiring diagram for your Benz to see what all happens on it.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Maria Stockstill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 867
