Ga door naar hoofdinhoud
Powers up when it feels like it
For the last 10 days my macbook turns itself off after about 20 - 30 minutes of usage. Then it takes about a couple of days before it will power up again. When it does start up it turns off when it sounds like a disc is being ejected. What could be wrong with my macbook, I can't afford another one as I live on a fixed income with SSD as my source of income I really need to fix this issue.
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
When the MacBook shuts off, do you still have a light on the AC adapter connector? Is it solid, or dimmer than usual?
I would remove the RAM, and try booting up with only one RAM module, and see if that makes a difference. If it doesn't, try with the RAM in the other slot and the first one empty. Sometimes A1181 RAM slots go bad and cause the behavior you're experiencing, in which case the machine will generally work fine if you keep the offending slot empty.
Beyond that, if the RAM thing doesn't help, I wonder if your machine may have experienced liquid damage, since liquid damaged boards sometimes behave as you describe. It certainly sounds like a hardware issue. I'd take off the topcase and see if there is any visible corrosion that you can clean off with q-tips and rubbing alcohol.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Will try. I was wondering if it was the uppercase as well as it was behaving weird with the keyboard freezing every once in a while.
door
Oh yes the adapter light is a solid green.
door
Try removing the battery and see if it will start up.
Score 2
1 Opmerking:
Did that it wont stay on. I push the power button on, the light on the front of the macbook lights up but the macbook does not turn on.
door
Do a SMC reset (SMC = System Management Controler). Take out the battery and remove the power chord. Press the powerswitch for at least 10 seconds. Wait a couple minutes and put everything back together.
Then you could also try a PRAM reset, athough in this case it's doubtful to do any good. Press and hold down the alt, cmd, r and p keys and power the machine on. Keep holding the keys til you hear the second chime.
Please report if that helped anything - if not we can go from there.
Score 1
7 opmerkingen:
Will try that now. Thank you I will let you know.
door
Did not work macbook still wont stay on keeps turning off like it went to sleep with the light on the bottom right hand corner lit.
door
In that case i'd recomment a complete stripdown and rebuild. These things love to have all connectors reattached. Hope you feel up to the job, manuals you'll find on this site.
door
It still doesn't work like it used to keeps turning off but it does stay on longer, Now it stays on for at least a couple of hours a day. Will replace keyboard/uppercase when I can to see if that is the issue.
door
Why would you replace the upper case for a power problem?
door
2 commentaren meer tonen
Okay replaced the upper case on my macbook still have the same issues. It will only powerup when it feels like it. I know its not the logic board, had it tested. Does anyone have an idea what it could be. I am in need of answers. Please help.
Voeg je antwoord toe
anttp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 409
