Changing iPhone 6s volume silent ringer switch cable need help!
Hi everyone I need some major help
im changing the silent ringer cable and volume cable light cable power cable.
Im having issues re assembling the silent ringer section as I’m finding the ringer switch won’t toggle between the 2. I have only tried without the screws in and also with out the bracket.
Would i I need to put the bracket on first?
Any help appreciated thanks
Update (02/09/2020)
Hi got round that issue but having another issue where the silent ringer switch works with the screen off the phone but with the screen attached it won’t work? Could it be the screen itself ? Or do you think there could be excess plastic on the screen ? Any help appreciated. Thanks
Is dit een goede vraag?
2 opmerkingen
Ok great is there a particular way I should glue it because I purchased just cable and will a bit of super glues do the trick? Thanks
door Rakesh
Guys i found the fix the bracket has 2 small bracket hook things on each end I didn’t put the switch inside that which was causing the issue. But now I’m finding another issue with the flashlight which isn’t actually being seated flush to the casing as it’s got 2 things sticking out preventing it from sitting flush any ideas?
door Rakesh
