Ga door naar hoofdinhoud
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
213 Vragen Bekijk alle
Why is my screen showing transparent icons on the background
I restore and update my iPad Air 2 and my screen started showing a layered transparent icons and display like in the attached image
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @cazio
There are two things that could cause this issue….
  1. The LCD didn’t refresh all the way during the reboot process and this screen will go back to normal once the software restore process is complete.
  2. OR
  3. The LCD has permanent damage known as “LCD Burn” and will need to be replaced to fix this problem. You can check for this when the iPad has completed the restore. Simply change the picture to a full white screen such as a new browser page to see if the marks are still there.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
you where right it was indeed screen burn and it washed away after keeping the screen on white for a while
door
Voeg je antwoord toe
Carlson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 3,442
