Ga door naar hoofdinhoud
Repair Guides for HP Desktops.
310 Vragen Bekijk alle
HP computer flashes red light and beeps 5 times
My HP computer flashes red light and beeps 5 times stops then 5 more on and on ,this at start up will not start . I have unplugged hard drive, memory stick replaced CMOS battery,still not starting. I have a new hard drive and CD Drive, but they are not installed for the current problem. Any ideas . Computer is HP elite Desk.
Thanks,
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
What is the full model number of the desktop?
Have you re inserted the RAM module (memory stick), you didn't say?
Having no RAM module inserted will give a 5 power light blink, 5 beep error code
If you have re-inserted the module and are still getting the error light/beeps, replace the module with a compatible replacement module and check if this resolves the problem.
If it still fails it may be a memory controller issue on the motherboard
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
If it's a memory controller issue, how can it be fixed?
door
@Lala Hetman
As a DIY repair you will have to replace the motherboard.
Alternatively you will need to find the motherboard schematics to find out why the memory controller isn't working
door
replace processor....
door
The possible reason as an overloaded power supply.    Disconnect all external devices to see if any of those items are causing the problem, (such as a hard, diskette, or optical drives, and expansion cards).  Power on the system. If the system enters the POST, then power off and replace one device at a time and repeat this procedure until failure occurs. Replace the device that is causing the failure. Continue adding devices one at a time to ensure all devices are functioning properly.
Score 2
Voeg je antwoord toe
Jeff Brewer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 25
Afgelopen 7 dagen: 275
Afgelopen 30 dagen: 1,111
Altijd: 34,065
