Ga door naar hoofdinhoud
Replacment V-Sync cable for 2011 21.5” iMac, where can I find and buy?
Hi all.
I have a 2011 21.5” iMac answer it’s all set up and ready to go, except when fixing it I broke the v-Sync cable, I’ve been having trouble finding any for sale. So I’d love some help from the community to see if they know where I can buy some from?
Cheers
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@quinn218 do an online search for apple part number 922-9799 or Apple manufacturing number 593-1389-A  which is the Cable V-Sync/LCD Temp Sensor for an iMac 21.5inch Mid 2011. Readily available and not overly expensive.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
@oldturkey03 - Good catch! I haven't needed to find one as I'd always had a junker or two to steal the part from.
Here's a source I found https://www.ebay.com/itm/Intel-iMac-21-5...
door
@danj @oldturkey03 So just to clarify, the V-sync cable also goes under the name "LCD Temp Sensor"? Thanks for your time.
door
@quinn218 it's a combination cable
door
Finding discreet display parts is always tough.
You’ll need to talk with one of the larger parts houses which recycle used systems. As an example in the UK TheBookYard I find them very helpful for odd requests. It may take a bit of time as they would need to strip down a bad display they get in for the part.
Otherwise you’ll need to replace the entire display assembly.
Score 1
Voeg je antwoord toe
Quinn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 167
