Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
106 Vragen Bekijk alle
iPhone XS won’t charge after charging port replacement
Hi,
i had to replace my charging port and everything seemed to work fine after I started it. However, the phone would only stay on for a few minutes, then turn off and on. Stay on for a few minutes, etc.
Now, when I plug it in to charge, it indicates it is charging, but doesn’t appear to be.
Im wondering if the charging port assembly is bad or if something else is broken.
Is dit een goede vraag?
Voeg een opmerking toe
Manta schroevendraaierset
112 bitjes voor elke reparatie.
Upgrade Your Toolbox
2 Antwoorden
Try wireless charging it. Does it charge up ? If yes, at least you know that the charging IC doesnt broke.
Also, try to recheck your insttalation. Whether there is any loose connection.
The fact that your phone only stay on for few minutes is quite worrying though
Was dit antwoord nuttig?
An iPhone XS that boots but restarts every few minutes is most likely caused by a faulty battery or dock connector.
Voeg je antwoord toe
Rob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 112
