Ga door naar hoofdinhoud
Won't turn on or charge
My Macbook won't even turn on or charge.
When I charge it. I see only a dim light on it.
After searching online I tried unplugging the battery and connecting the charger. Usually in videos it gets fixed after that. But it didn't for my case.
So I'm wondering if I need to change the magsafe jack or my board is fried.
Is dit een goede vraag?
1 Opmerking:
If you are seeing a dim light on the MagSafe charger (Green) that would imply the charging logic within your system has a problem.
door
Voeg een opmerking toe
1 Antwoord
What does the battery checker within the battery tell you? Are you getting a full set of LED's when you press the checker button?
Was dit antwoord nuttig?
2 opmerkingen:
It won't show any light.
How much does that cost? And is it a hard job replacing it?
door
Sadly, you'll need a new logic board which is hard to find for this series. Maybe someone local to you has the skills to fix your logic board as thats the only option.
door
Voeg je antwoord toe
jagroop bhumber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 140
