Having problems with keyboard.
I just replaced the logic board. The macine will only boot up on the battery, and there is no keyboard control, or back light. Can not charge machine with wall charger, even though I get a green light on the charger. I was thinking about the left I/O board, but don't understand why the keyboard won't funtion when its pluged into the logic board, and there is enough power on the logic board to boot the macine, and run the screen. Does anyone have a sugjestion as I would should try next? Should the keyboard be working?
Is dit een goede vraag?
4 opmerkingen
Did you buy the logic board knowing it would work? That would stink if you bought it from eBay and the seller lied about its condition. I've been there MANY times.
door TommyJames337
Well, I would assume that ifixit would sell me a board the works.
door KMOGI
What was it doing before the logic board replacement? Why did you replace the board? Did you change board speeds?
door mayer
When the machine was powered up, I would see a flashing white light in the front. and slight noise from the optical drive, then nothing.... from looking around replacing the logic board would be the first step.
door KMOGI
