Ga door naar hoofdinhoud
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Vragen Bekijk alle
13" MacBook Pro won't boot after battery replacement
Hello everyone, got a late 2013 13” macbook pro that refuses to turn on after replacing the battery.
Before the replacement, the battery life was always very faint. Although it would charge, it’d never hold its charge for long. The battery was replaced by a fellow tech of mine, and she said everything came on just fine when testing it after doing the replacement. I’m going to double check with her again to make sure she’s certain of this. However, the customer came in to pick it up and it just won’t boot.
Absolutely nothing comes on when I try to boot. Not the fan, any lights or the screen - nothing. It appears that the logic board just isn’t getting powered. When the charger is plugged in, it lights up red. I don’t know if the laptop is suppossed to turn on when plugged into a charger, but it doesn’t when I plug it in. I’m leaving the laptop plugged in over night, and I’ll check to see if it’s lit up green in the morning.
I’ve tried resetting the SMC, but no dice. Everything appears to be hooked up correctly after the replacement, but I can’t be certain until I run through a battery replacement again and check all the connections. I really trust my tech on this one, but I’m planning on tearing it down tomorrow morning to see for sure.
Is there particular connection that I should be looking for when tearing it down in the morning? Is there a chance that the logic board/battery isn’t getting power? Or maybe some other thing is at play here?
Any advice you guys may have would be greatly appreciated!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Pure speculation: someting is shorted on the board and battery got drained in the time between test and customer pickup, that’s the only explanation I can think of. Now on to the troubleshooting: disconnect battery from the board that would start by itself at magsafe plugging in, if still alive. Amber light on magsafe is useless for any real info except the onewire protection circuit is probably working.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
If the board got shorted, does that mean it's dead for good now?
door
@gmb53236 Before over-worrying I'd try what happens without battery first and in case the problem is still there try to rule out other possible faulty components. If board would be shorted it would need a component level repair or a replacement.
door
Voeg je antwoord toe
Gene McBean zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 287
