Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1062 Vragen Bekijk alle
Old Ps4 will glitch out and then shutdown?
As of a couple months ago, my ps4 (not coming from ps4 itself but the tv audio) just randomly started screeching combined with the screen glitching out and flashing a bunch of random bits before it completely shut off. after a long period of testing, the ps4 will also do this same thing if i press down on it in the top right quadrant, or sometimes if i play a game that is intensive. (i.e. bo4 will kill it but hollow knight is fine). although there has been periods of time where it's worked without problems (aside from it shutting off and glitching out if hit or bumped around that area), but it will eventually start crashing again. I believe it might be the power supply but i haven't seen this happen to anybody else on any forums so im confused. also it is very dusty on the inside and would have the fans spinning constantly despite where i had it (out in the open or in a cabinet)
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Antwoord
Gekozen oplossing
That is a problem with the APU (Accelerated Processing Unit / CPU + GPU combo) processor developing a loose connection which happens either from overheating and/or the console being dropped. Usually only the 2015 launch models a batch of them suffer from this fault.
Only solution would be to do the washer trick first which may make the console work fine again for a month or if lucky a year at best.
PlayStation 4 Turns On Then Back Off Repair
The other solution which is not economically viable is to reball the APU which requires a BGA rework machine ($2,000+) and lots of experience with micro-soldering.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Romen Balladarez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 21
