Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
I can’t get the home button bracket screws out!
Hi,
I have repaired 2 iPhone SEs so far, and every single one I have found the two screws over the home button bracket very hard to get out. I have ripped the bracket out successfully twice, but because of the shattered screen on this one, I cannot get it out at all! The screws are also now stripped!
Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
On water damaged SE’s I have drilled the left screw out than covered the home button components and applied super glue to the screw on the right.
I than bend the bracket up from the left and turn the bracket hopping the right screw will come loose. If this doesn’t work I drill it out.
They are easy to drill out if you have the right tools. I use a Dremel with dentist bits. If I were you I would invest in some quality drivers for removing the screws.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I’m definitely going to hive drilling a go, however where can I get the correct type? I searched for one, but had no matches. Thank you.
door
I think I purchased mine from iPad Rehab but that was years ago.
door
Voeg je antwoord toe
TheRe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 106
