Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Vraag afgerond
3Gs DOES NOT sync with I TUNES AND THE PHONE TURNS OFF
the phone does not want to sync with i tunes and it turns off with out sync then turns on again and start the process again many times with out stopping .
Is dit een goede vraag?
3 opmerkingen:
sounds like it is time to replace your battery. Apples iPhones a and iPods do weird things with a bad battery. At least it will give you a good starting point.
door
This question was migrated from http://www.ifixit.com/Answers/.
door
This question was migrated from http://meta.ifixit.com/.
door
Voeg een opmerking toe
1 Antwoord
Don't replace things without knowing they need to be replaced. If the battery does not last long or acts weird, then I'd replace it. But I'd try restoring if you can. That may be your issue. It's definitely an issue with your iPhones and nit the computer. Has it had water damage?
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 382
