Ga door naar hoofdinhoud
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
459 Vragen Bekijk alle
Display backlight died again after replacing logic board
I obtained a water damaged Macbook Air whose display backlight wasn’t working. I replaced the logic board, and after that it worked fine, until today when the backlight went out again. Any diagnostic steps I can take to figure out what the actual problem is? I don’t want to replace the logic board again without knowing what the issue is.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If you have a multi-meter on hand you can measure the capacitors near the display connector in order to see if there’s backlight voltage present. if its missing (I Suspect it is) you can also check the fuse and check for a short across the capacitors to see if it might be a simple repair.
Was dit antwoord nuttig?
Voeg je antwoord toe
Tyler K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 37
