Sputtering Engine & Bad brakes out of nowhere!
2003 MPV started sputtering really bad and brakes easy then hard to press. Both occurred at the same time and overnight.
Is dit een goede vraag?
Hi @bookwormdmc ,
Check if the brake booster is working OK.
Here’s how to do this
With the engine off, pump the brakes — about five or six times is sufficient. This depletes the stored vacuum.
Turn the engine on while pushing down lightly on the brake pedal. If your brake booster is working normally, the pedal will fall away a little, but then become firm.
If your brake booster is not working correctly, nothing will happen, or the brake pedal will push back against your foot once the engine starts. This could be a sign of a brake booster problem or an issue with the vacuum hose.
A faulty or loose vacuum hose could also affect the engine.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 27
Altijd: 339
