Ga door naar hoofdinhoud
Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Power and volume buttons sunk inside the body of Oneplus 3
So, the power and volume buttons on my OnePlus 3 started feeling a little weird lately and slowly one by one all just kind of sunk inside the body of the phone and stopped working altogether. So, I opened the phone and found that the actual internal buttons were fine and working, but the rubber thingy that pushes those buttons from outside and worn out and was unusable. So, does anyone know if those rubber thingys can be replaced or is there any diy hack to make them work or do I need to get the whole back cover replaced?
Is dit een goede vraag?
Score 1
1 Opmerking:
The same thing happened to my notepad..what do I do?
door
Voeg een opmerking toe
3 Antwoorden
The same thing happened to me a few months ago. The power button went first, and then the bottom volume button some weeks later. I changed my phone battery today and discovered the little plastic bits had basically degraded and crumbled. So now even though my phone is charged up, I can’t get it to turn on and I haven’t seen anything on any forums about what to do about this specific problem. You posted this since 2019, have you had any luck since then? Buying a new phone is not an option for me.
Was dit antwoord nuttig?
1 Opmerking:
Well, sorry for the late reply. Unfortunately, my Oneplus broke completely before I could get it fixed. The only way to fix this is to replace the complete back housing. So, if you could get a after-market housing, that's the only way to get the phone working properly
door
There is an inherent fault on the case buttons of the OP3/3T. The Rubber plungers that make contact with the internal ribbon cable button fails over time, it goes hard and brittle, then crumbles. The case buttons need replacing. To do this you require to remove the back case (follow the instructions). Running down either side of the case is a granular adhesive strip. Using tweezers, peel this back carefully until you go past the case buttons. You will see a tiny metal spring clip that tensions the case button in place. Using tweezers again, gently lift that off. You can then push the button from the inside and it will fall out. Then replace with a new button in reverse order.
If there is a button still working, measure the plastic length after opening the phone. Take out any remaining crumbling plastic. Use UV Glue to mold it to the same size as the working button. Harden it gradually to mold it to the correct length. Put the casing back on and your button should be fixed.
Voeg je antwoord toe
Vandan Bhardwaj zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 54
Altijd: 1,292
