Ga door naar hoofdinhoud
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Vragen Bekijk alle
My pc just stop displaying when on load my gpu or psu's fault?
whenever I try and run anything demanding ie: 2 tabs of youtube, counter strike, etc
My pc crashes. but the sound still works fine, I can hear everything that was playing before it turned off, but inputs and display stop running
What I’ve tried:
Re-installing windows
Trying different 8 pin connectors to power my GPU
using an i7 4770k to see if my CPU was the problem
using a different monitor
Specs:
i74790k
gtx 970
Cooler master g750m power supply
gigabyte z970x-soc force mobo
2 random hard drives
Any help is appreciated :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would first completely uninstalling the graphics driver using Display Driver Uninstaller in Safe Mode:
https://www.majorgeeks.com/files/details...
following their instructions.
Then reinstalling the GTX 970 drivers.
If this fixes the problem then you are good, if not then
I would:
  1. Resocket the memory cards.
  2. Test the system RAM using Memtest86 Free https://www.majorgeeks.com/files/details...
  3. If problems found then try one module at a time and see if problem goes away.
Any how a start. Let us know how it goes.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Abhijeet Sharma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 59
