Ga door naar hoofdinhoud
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
Why is my screen lit up , but won't let me use the calculator?
I haven’t used my Ti-nspire in a while, and I plugged it in to charge it today and the screen will only light up white. But, I have tried to reset it and also take the battery out and it still won’t work.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
First, check your battery, make sure it hasn’t corroded or damaged the calculator somehow.
Next, I think your best bet is to try to re-install the OS. There’s a guide on that here: Texas Instruments TI-Nspire CX OS Replacement
If that doesn’t help, try reaching the diagnostics menu or the maintenance menu by following one of these combinations I found on TI-Planet:
3) TI-Nspire CX/CM:
  • [esc]+[menu]+[-]
  • launches the diagnostic software, if present (non-dangerous choice)
  • [doc]+[enter]+[EE]
  • Goes to the Maintenance Menu (allowing you to delete the OS, etc.) (no effect if nothing if cancelled - not dangerous
Was dit antwoord nuttig?
Voeg je antwoord toe
Megan Nightengale zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 28
Altijd: 2,429
