iMac won't turn on
It does not work, when opening the iMac from the inside, I found that when I press the power button only the fans turn on and then turn off
Update (12/08/2019)
Only LED #1, what’s the problem now please
Is dit een goede vraag?
In the bottom left corner of the logic board is a strip of tape covering over the onboard diagnostic LED’s. Carefully remove it so you can see them. Tell us what you see.
Here's a breakdown of the onboard diagnostic LED's:
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 71
1 Opmerking
Did you try a new PSU? As stated under LED 2.
door Dan
