Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
110 Vragen Bekijk alle
iPad keeps restarting after 2 minutes. Replaced screen.
Hi.
Got a customer that changed the screen on his iPad by him self. The replacement went approximately ok, but the iPad keeps restarting every 2 minutes and 30 seconds.
He told me that he did not separate the logic board from the battery connector when he disconnected the old screen and connected the new screen…
When he connects the old screen again, the iPad do not restart every 2 min…
It´s an original screen.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I would try a different screen. All 3rd party apple screens can cause the device to do erratic things such as this one. I’ve come across this issue a few times when replacing screens and it seems to always fix the issue.
Was dit antwoord nuttig?
Score 1
I have exactly the same problem with my ipad pro 10.5.Change the original broken screen with a 3rd party screen but forget to disconnect the battery first so when i placed the new one the ipad restarts every 2-3 minutes.When i put the broken screen everything is ok.Now i have ordered a new screen and cross my fingers to fix the problem..
Commentaar:
how was it, did it work by trying to install another new screen?
door
Hey,
Maybe there is no certain answer to know whether it is the matter of the new screen. But if you want to solve the iPad keeps restarting, you can do the following:
  1. Hard restart your iPad
  2. Use a tool to restore your iPad via iTunes or TunesKit iOS System Recovery
Voeg je antwoord toe
alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 57
Altijd: 1,015
