Ga door naar hoofdinhoud
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
20 Vragen Bekijk alle
Can't access BIOS and skips to windows
First off here are my system specs:
Intel I7 8700k
16GB G.SKILL TridentZ RGB Series DDR4 3000
GTX 970 SSC ATX 2.0 in SLI
Aorus Z390 Ultra Motherboard
Evga 1000w PSU
Samsung Evo 970 1TB M.2 with Windows 10 Pro 64 bit
All of a sudden I do not see my Aorus splash screen anymore. Instead it skips all of that and I goes straight to a desktop log in. Funny this is if I hit delete I can tell it enters the BIOS but I have no video signal to my monitors. PC behaves totally fine otherwise. Get a post beep and all of that. Soo what's going on here?
Overall it seems like a video problem. I’m not getting a video signal until windows loads.
Should I try to reset the bios and pull the CMOS battery? Maybe a bug in the Nvidia Driver?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @tvandell
Is it a multiple monitor configuration?
you can try this
https://www.thewindowsclub.com/boot-wind...
additional
check for any bios updates for your mainboard.
when in bios, check if PEG graphic has been set to primary.
sometimes there are mainboard setting which can activate fast boot, thus POST clear very fast and boot to windows
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hi @tvandell ,
To add to @salmonjapan's answer, try entering BIOS through Win 10 settings
Alternatively disable fast startup Win 10 and check if you get the splash screen and can enter BIOS OK when you restart the desktop
door
Voeg je antwoord toe
Travis A VanDell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 2,659
