Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 Vragen Bekijk alle
Front panel won’t close flash at digitizer ribbon cable area
Can’t complete front panel replacement. Home button & digitizer ribbon cables won’t let me close front panel against chassis. Any suggestions how to place those ribbon cables so they are not on the way?
Is dit een goede vraag?
2 opmerkingen
Make sense. You can tell how bended original cables was. I’ll try to fit them underneath chassis empty space.
door
Yeah it’s really tricky. Just to be safe I used heat gun to make ribbon cables more flexible and accurately fit cables underneath chassis and digitizer fit perfectly in place .
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Is it the Touch Screen flex cable that is on the way preventing to proper assembly?
If yes, they go “hidden” behind the LCD and a little part goes hidden “inside” the chassis.
Is tricky and very hard to explain in words how to do it. I would recommend to look up for some videos “iPad Mini 3 Screen Replacement” and attention to details, this is the most important one.
Good luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
bohdanhl93 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 80
