Why is my Soundfreaq sound kick not charging?
After long frequent use, the speaker no longer charging and power light not turning on, cord fits loosely. I opened up and no apparent damage. Suggestions?
Is dit een goede vraag?
@ilovelucy24680 check the charging port for power when you have the charger plugged in. It is possible that the port simply wore out. To replace it you would need to measure it etc. and use that information to try and match one with some ports available at mouser.com or digikey.com. Also, replace the battery while you are at it. Use this teardown to get into it. Use this Voeg afbeeldingen toe aan een bestaande vraag to add your images if you need further help, with your QUESTION.
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Handleiding
Moeilijkheid:
Gemiddeld
15 minutes
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 1,574
